clucth kit
roon101
clucth kit
Postby roon101 » Sat Oct 23, 2010 7:59 am
sure kendo will give me some advice but if i put a clutch kit in my 500 will get rid of the throttle lag when i first take off and give me a small boost of tourqe for tight spots i never put a clutch kit in anything in my life never saw a use for it till now
and most of the stuff i rode had manule clutch
any info would be great.
Re: clucth kit
Postby Kendo » Sat Oct 23, 2010 9:38 am
Yes it will. You may not need an entire kit, sometime a simple spring change or weight change will get you what you want. I switched to an '06 800 clutch recently and I can't believe how much of a difference it made!!
I had/have a Dalton kit in my old clutch and it worked great. The driven clutch on the 800 is different though, and it engages almost immediately.
roon101
Re: clucth kit
Postby roon101 » Sat Oct 23, 2010 12:49 pm
is a clutch kit somthing i could do in a weekand in my garag.
ATV'er
Re: clucth kit
Postby ATV'er » Sun Oct 24, 2010 10:33 am
I got my clutch from epi. You can take the clutch out yourself. But I had to have the dealer rebuild the clutch. I think it took them no more than a hour to rebuild.
Re: clucth kit
Postby Kendo » Sun Oct 24, 2010 5:48 pm
Depends on you really. Can you change a belt in your garage? The kit I installed only required a spring and weight change. Took me a little longer than a belt change, because I pulled the clutch to swap the spring. You'll need a clutch puller, I made one by machining the center out of a 3/4" bolt and putting an old fuel pump pushrod in the center.
ATV'er
Re: clucth kit
Postby ATV'er » Sun Oct 24, 2010 5:57 pm
http://www.erlandsonperformance.com/mm5 ... =utlitykit
Here is the link. The kit I got was for the larger tires and for the heigher elevation. It works awesome.
Re: clucth kit
Postby Mr. Green » Mon Oct 25, 2010 11:12 am
un sure of polaris but the clutch should be almost the same as can am's and most clutch kits are just a spring and some wights or some times just a spring. I have not done it on mine but you would have to pull the primary clutch to do it of course and that takes some redneck ingenuity or a factory tool most times (at least for can-am's). It looks like from kendo's post that polaris is the same.
Re: clucth kit
Postby Kendo » Mon Oct 25, 2010 1:50 pm
Mr. Green wrote:.....some redneck ingenuity.....
You callin me a redneck?!?!? :lol:
Re: clucth kit
Postby Mr. Green » Mon Oct 25, 2010 10:24 pm
Not at all, most rednecks cant make ...
Kendo wrote: machining the center out of a 3/4" bolt and putting an old fuel pump pushrod in the center.
now if you would have drilled that bolt out with a hand drill and vise grips and used welding rod... that be redneck
Im just saying you have to make something your self how ever you can or buy the factory puller bolt. I admit i bought the bolt. I have some areas in there that need to be greased ever 100 hours so i just bought the factory bolt it was worth the $20 bucks.
But yes your a redneck..
cwlongshot
Re: clutch kit
Postby cwlongshot » Fri Dec 31, 2010 8:29 am
Here is a series of four short vids showing the entire process...
http://www.youtube.com/results?search_q ... stall&aq=f
http://www.youtube.com/watch?v=jfSkSmjQOmM
http://www.youtube.com/watch?v=6OevZEk26K4
http://www.youtube.com/watch?v=er30MSL_gfg
http://www.youtube.com/watch?v=2e5Kdflo8pc
I have a slipping belt in my 700. I bought the machine last October, it was a plow only quad. I guess the guy used HI range too much.
I will go with the EPI Sport Ute kit for larger tires as I am also upping the tire size next year. Likely Bighorns in 27"
CW
