2005 Sportsman 700 EFI fuen pump not working
Ken's700
Postby Ken's700 » Thu Jul 08, 2010 9:11 pm
Anyone have any ideas what could be the problem?
I did the code check and all that came up was code 61 (end of codes)
I have power (fresh charged battery) when you turn the key on there is no fuel pump sounds like normal but the engine turns over fine.
Thanks,
Quads No More :(
Re: 2005 Sportsman 700 EFI fuen pump not working
Postby hemingray » Fri Jul 09, 2010 11:27 am
I'm no Polaris expert, but could it be that the fuel pump itself is dead? I would try and check for 12 volts on the pump supply leads to see if there is voltage at the pump. If there is - then the pump itself is bad.
Good luck!
Ken's700
Postby Ken's700 » Sun Jul 11, 2010 8:54 am
Thanks hemingray, I try that out.
Quads No More :(
Ken's700
Postby Ken's700 » Sun Jul 25, 2010 2:05 pm
Fuel pump was the problem. I have less than 40 hrs on that machine :evil:
Quads No More :(
Ken's700
Postby Ken's700 » Mon Jul 26, 2010 10:45 pm
I hate that you have to replace the fuel tank with the pump!
Quads No More :(
Postby hemingray » Tue Jul 27, 2010 8:36 pm
Wow, THAT sucks. On the other hand, you'll be riding again! ;-)
Users browsing this forum: No registered users and 5 guests
